11 years ago.
FRDM k64f is not Responding
/media/uploads/mokhanaf/main.cpp There is something wrong with my board! when I drop the .bin file in to it, it gets hot and it's not responding, can anyone help me to fix it? /media/uploads/mokhanaf/speaker.h
You will need to give more information than this. Which bin file? And where are you dropping it in? Did you do the mbed firmware update?
posted by Erik - 16 Mar 2015
There should be a guide how to ask a question or report an issue, when writing a new one.
posted by Martin Kojtal 16 Mar 2015
I am Working on PIR-motion sensor project and I am using mbed firmware, the problem is after boot loading the k64f and compile my code, I drag it to the mbed drive but the board is doing nothing not even blinking the led!
posted by Mona Khanafriboor 16 Mar 2015
11 years ago.
It's probably a problem with your circuit, e.g. a short to ground or you are trying to draw too much current from a pin. Unplug everything from it and try again.
Thanks Tim, I think that what happened. I miss connect the external power (9v) battery in order to run my program; when motion detected the buzz should ring. If you have any idea on this manner please let me know.
posted by Mona Khanafriboor 17 Mar 2015
