-deleted-
11 years ago.
Is there an FTP Client code example?
Where can I find a code example for an FTP Client for the mbed IP library over Ethernet? http://developer.mbed.org/users/mbed_official/code/EthernetInterface/
I could use the mbed device as a server with TFTP or FTP: https://developer.mbed.org/search/?type=&q=TFTP] or [[http://developer.mbed.org/search/?type=&q=FTP+Server
I want to be able to upload a file via FTP onto a microSD card attached to the mbed device.
What is the best way to do this?
11 years ago.
Ed, This one I stitched together earlier /media/uploads/dflet/tftpservertest.zip . It compiles with one warning easy to fix. I have run it SD appears to work as well as the TFTP part. I have not tested it in anger, I didn't want to take all the fun away.
Edit: It compiles for an lpc1768, if you use another uC then change the pins in main.cpp.
Thank you David. I appreciate your support.
posted by -deleted- 16 Mar 2015
