11 years ago.
Using an RtosTimer inside a class
I'm trying to use an RtosTimer within a class but the mbed locks up. I think this is because I'm calling threadHelper each tick and its creating a new pointer whereas I actually want to call threadMethod each tick or call threadHeper each tick but use the same pointer.
Can anyone show me how I should be doing this?
The code below works for an RtosThread because threadHelper is only called once, but I need to use an Rtos Timer.
#ifndef TEST_CLASS_H
#define TEST_CLASS_H
#include "rtos.h"
/** TestClass class.
* Used for demonstrating stuff.
class TestClass
public:
/** Create a TestClass object with the specified specifics
* @param led The LED pin.
* @param flashRate The rate to flash the LED at in Hz.
TestClass(PinName led, float flashRate);
/** Start flashing the LED using a Thread
void start();
private:
//Member variables
DigitalOut m_Led;
float m_FlashRate;
RtosTimer *m_rtosTimer;
//Internal methods
static void threadHelper(const void* arg);
void threadMethod();
#endif
#include "TestClass.h"
TestClass::TestClass(PinName led, float flashRate) : m_Led(led, 0), m_FlashRate(flashRate)
//NOTE: The RTOS hasn't started yet, so we can't create the internal thread here
void TestClass::start()
m_rtosTimer = new RtosTimer(&TestClass::threadHelper, osTimerPeriodic, (void *)0);
int updateTime = (1.0 / m_FlashRate) * 1000;
m_rtosTimer->start(updateTime);
void TestClass::threadHelper(const void* arg)
//Cast the argument to a TestClass instance pointer
TestClass* instance = (TestClass*)arg;
//Call the thread method for the TestClass instance
instance ->threadMethod();
void TestClass::threadMethod()
//Do some stuff
Thanks
