11 years, 1 month ago.
Does mbed support persistent storage access operation ?
Are there any API about persistent storage access operation in mbed ? Such as Flash interface, Filesystem.
Maybe it is on the way?
If your chip has extra flash (like the LPC1768), then you can use the LocalFileSystem. If not (like the FRDM-K64F), then you can use an SD card.
http://developer.mbed.org/cookbook/SD-Card-File-System
Thank you very much. but why LocalFileSystem calls semihost function ? Does it work with Flash driver ? By the way, there is no SD card in my project.
posted by Chunqiang Li 07 Mar 2015
Some of the mbed boards have user-writable flash in the 'magic' mbed interface chip that acts as the USB programmer and serial port.
If yours doesn't (or you're prototyping for a production device that won't have the mbed interface), then you'll need to either add an external flash chip (eg the M25P family) or use the platform-specific functions to write to an unused part of the program flash.
There are several libraries for external flash chips, not sure about on-chip program flash.
Which platform are you using?
posted by Richard Thompson 07 Mar 2015
There is Flash memory in my board(nRF51822). but when I imported mbed-src to my project, I found following codes in LocalFileSystem.cpp:
ssize_t LocalFileHandle::write(const void *buffer, size_t length) { ssize_t n = semihost_write(_fh, (const unsigned char*)buffer, length, 0); number of characters not written n = length - n; number of characters written pos += n; return n; }
ssize_t LocalFileHandle::read(void *buffer, size_t length) { ssize_t n = semihost_read(_fh, (unsigned char*)buffer, length, 0); number of characters not read n = length - n; number of characters read pos += n; return n; }
The APIs call semihost_*. Does semihost_* call the flash driver of nRF51822 finally ?
posted by Chunqiang Li 09 Mar 2015
