13 years ago.
Internal file system KL25Z
Good morning! I'm designing an electronic lock using KL25Z, I need to store the unlock code. Can I use a text file (.txt) stored on the internal file system using the same methods used for the LPC1768?
13 years ago.
No, the KL25Z does not support a internal file system, because there is no external Flash. There is a socket U5 on the board for a AT45DB161 flash, but the firmware does not support this today ...
You can add a small SPI or I2C EEProm to store the code. It is also possible to write the code into a not used KL25Z flash page, but I think there is no library for that at the moment.
thank you! but if you want to change the unlock code as I do not lose after power off the system?
posted by Davide Luongo 21 Mar 2013
there is another way to save data in the system is off?
posted by Davide Luongo 23 Apr 2013
12 years, 11 months ago.
Thank you
