11 years, 1 month ago.
How to program a fan controller on mbed Application Board with a LPC1768?
Hi all,
I'm planning to make a PC fan controller but i don't know how to program it. I want it to display the RPM of the fan as well as the voltage im putting into them. I also would like to be able to control the fans with a rotary dial that controls voltage output to 0-12v.
Thanks all!
All of what you want is doable. There are examples of how to do each stage already in the system. If you don't know how to program it then learn.
No one is going to write the program for you. Make an attempt and ask questions about specific problems or start a forum thread and you'll get a lot more help.
posted by Andy A 27 Feb 2015
most PC fans will poop out at about 8vdc, usually need to be started around 12v, then ramp down
posted by Gary Z 05 Mar 2015
