11 years, 1 month ago.
How Can I upload surce code to the microcontroler?
Dear All, What is the procedure step by step to upload my surce code for nucleo . When I started compile I got onlu bin file and what is next step?
My file name from the compiler is different from the firmware that is already loaded on the device I purchased. Do I need to change the file name first?
posted by Richard Ciampa 25 Feb 2015
Plug the board in to your computer, you should see a USB drive show up, if not install the mbed drivers.
Copy the .bin file from the compiler to the USB drive (if you get a drive full error remove the .bin already on there)
Press the reset button.
No, no need to change the name.
posted by Andy A 25 Feb 2015
