10 years, 2 months ago.
Please help
, i cant use the compiler, My programs is empty, how fix this.
Email support and ask if they can retrieve anything. They may be able to help.
Had you committed or published any of the programs? If so there should still be a copy of them somewhere. If you never hit commit or publish then they may be gone.
Always commit/publish code once it's working. Not only does it give you a history of the code and make changes easier to back out, it also creates a second copy of the files. Not doing so is a bit like never backing up the files on your computer, it only takes one thing to go wrong and you've lost everything.
Not sure if this is the same problem, but I had a similar issue a few days ago. In the middle of an editing session, suddenly all files in a projects were shown ''empty''. The files and lib structure was still there. I could still compile the project and that resulted in an executable binary. I could export the project as a zip file and that had all source code when I inspected the zipped files. I then rebooted the PC, restarted the browser (Chrome) and everything was showing again. So the problem seemed to be a browser issue.
Jorge,
Are you still experiencing this issue? I can see that you've been using the compiler and can't see anything that should be causing issues in the compiler.
If you are still having problems can I ask you to email support@mbed.org
Thanks
Steve
