11 years, 1 month ago.
Re Nordic Pucks: Is this project usable now?
Did an import (with the Nordic nRF51-DK as target platform) and attempted to compile. Lots of missing symbols, starting with Serial logger.
Newbie to mbed here (but lots of nRF51822 BLE development using the Keil MDK). Was under the impression that importing a sample program pulled along all the required support code, libraries, etc.
Is that not the case for Puck? What else needs to be added? How?
TIA,
Mike
When importing the Puck library, did you have the label 'update all sub-libraries to the latest revision' checked?
Unfortunately, Puck hasn't been updated to work with the latest version of the BLE API, which means this box needs to remain unchecked for the library to work.
Thanks for the quick reply. Yes, I did check the "update all sub-libraries" box. Will try again without.
BTW, what would you recommend for a good base template for nRF51-DK BLE (S110) apps? When using the Keil MDK, I started with Nordic's AN-36, with the ble_lbs_svc. Did import the HRS example here, which compiled and runs fine.
Mike
posted by 12 Feb 2015Stian,
Gave it a try without checking "update all sub-libraries..." Closer, but still not OK. Fails on:
/#include "compiler_abstraction.h"
in app_util.h
No problem, You've convinced me that I'm better off basing my work on more current BLE samples :-)
Thanks again for the feedback.
Mike
posted by 13 Feb 2015+1 I also get the error about (NOT updating the libraries to the latest) /#include "compiler_abstraction.h" in app_util.h"
posted by 21 Feb 2015
