11 years, 1 month ago.
NTPClient::setTime returns NTP_OK even when ethernet cable is unplugged?
I was trying to use NTPClient::setTime as a way to check whether internet access is available, somehow it doesn't work. As stated in the tittle, even when Ethernet cable is unplugged, setTime returns 0(NTP_OK).
This seems rather wired. Did this happen to anyone of you?
Thanks, ZL
Hi ZL,
Donatien's sample is simplified, to focus the reader only on the NTP client functions. For a more detailed, and robust solution, the program needs to check the return values from the prior function calls.
This is extracted from one of my applications (and then I modified it for the NTP example).
RawSerial pc(USBTX, USBRX);
EthernetInterface eth;
// This function returns the current status of connection.
bool get_link_status(void)
uint32_t tmp = lpc_mii_read_data();
return (tmp & DP8_VALID_LINK) ? true : false;
pc.printf("Initializing network interface...\r\n");
if (0 == eth.init()) {
// It should always take this path
do {
pc.printf("Connecting to network...\r\n");
if (0 == eth.connect()) {
pc.printf("Ethernet connected as %s\r\n", eth.getIPAddress());
while (get_link_status()) {
//pc.printf("Connection is good.\r\n");
if (pc.readable()) {
int c = pc.getc();
switch (c) {
case 'r':
mbed_reset();
break;
case 't':
if (ntp.setTime("0.pool.ntp.org") == 0) {
printf("Set time successfully\r\n");
break;
default:
pc.printf("Menu:\r\n"
" t - Time set from NTP server.\r\n"
" r - reset\r\n"
break;
} // switch
} // if pc.readable()
} // while (get_link_status())
pc.printf("lost connection.\r\n");
eth.disconnect();
} else {
pc.printf(" ... failed to connect.\r\n");
} while (1);
} else {
pc.printf(" ... failed to initialize, rebooting...\r\n");
mbed_reset();
