10 years, 1 month ago.
ntcD5-9 Steinhart coefficients
Hi. I need the Steinhart coefficients (A , B and C) of ntc5D-9. Thank you for any help.
Hi
You can calculate the Steinhart-Hart coefficients from 3 measured data points. The equations are here in the section coefficients.
https://en.wikipedia.org/wiki/Steinhart–Hart_equation
I found a data sheet with the temperature curve for this part. You could use the centre resistance for the calculation too.
http://www.microtech-hk.com/dl.php?itemid=PR01931&id=D031033
This part has a resistance of only 5Ohm at 25°C. If you want to measure around room temperature and higher maybe a thermistor with a resistance of 10K at 25°C might be better
