10 years, 1 month ago.
GNSS receiver is not available
Hey,
I connected my C027 and played with C027_ModemTransparentSerial_UBLOX_C027 and C027_GPSTransparentSerial_UBLOX_C027
Everything works great, except when I'm using m-center and trying to get location from the GNSS I get "GNSS receiver is not available" And I can only use Cell Locate which is only using Triangulation on the cells right? and is not accurate enough.
Any ideas?
Thanks, Dan
Hi Dan,
First of all, I advise you to use u-center for GNSS module evaluation. The "m-center" tool is for evaluation of cellular modules. Sure, you can interface GNSS module also with m-center, you should receive continuous NMEA messages in the terminal..
Which example program do you use when seeing the "GNSS receiver is not available" message? Can you provide more details? I think you are interfacing cellular module while your GNSS is powered down..
Hope this helps, Jaka
Hey Jaka,
I used both u-center and m-center to test all the capabilities. So like you said the GNSS works while I'm using the u-center, and I do get the NMEA messages in the terminal.
I get the "GNSS receiver is not available" message when using the "C027_ModemTransparentSerial" and m-center, in the Positioning tab clicking the GNSS Test button; As I understand it should work because the cellular module is connected to the GNSS using the DDC (I2C) interface.
Do I need to turn it on first? If so, how can I turn it on?
Thanks, Dan
posted by 29 Jan 2016
