10 years, 2 months ago.
"No mbed microcontrollers were found"!!
I got "No mbed Microcontrollers were found" even though my Nucleo is attached (in fact I have already programmed it several times through it)
on the other hand what does "no explorer drive windows open, run the installer" means???
Do I need to install any drivers for the STM32 (so far they were not necessary) The device manager shows the ST-link debug device with a yellow exclamation mark However as I said so far I had no problem programming the nucleo
Help please
Resolve the yellow exclamation mark by installing the referenced ST-Link driver from this webpage:
https://developer.mbed.org/platforms/ST-Nucleo-F091RC/
and the rest should follow with the storage drive letter, etc.
After I installed the drivers, I didnt need to install the serial driver... is this correct..?
I still sometimes have some problems with Teraterm not recognizing my port... sometimes it works sometimes it doesnt
posted by Cristian Fuentes 22 Jan 2016
Update #2
Can you try with Realterm ? There is some delay in detecting the supported COM port after the binary code is saved -> target board is then automatically rebooted / restarted and then a few seconds later the COM port is enumerated (detected). Can you view your Device Manager to see the results of your testing ? If Device Manager can see the COM port then start Realterm and the same COM port should be detected.
http://realterm.sourceforge.net/
posted by Sanjiv Bhatia 26 Jan 2016
