10 years, 2 months ago.
Markup/Formatting problem in a comment
I don't seem to be able to get the formatting/markup right in my comment at https://developer.mbed.org/users/igorsk/notebook/mbed-memory-usage/?page=1#comment-1480.
The edit post panel does not present me with the "Editing tips" link or the "show preview" button, and the result ignores all my attempts to format the code with <<code>> and <</code>>. Can anyone point me in the right direction?
Thanks for your help.
You are putting <<code>> and <</code>> each on their own line? e.g. <<code>> Your code <</code>> should give
Your code
while failing to do that breaks it e.g. <<code>> Your code<</code>> results in
<<code>>
Your code<</code>>
That's the normal cause of problems but in that situation I would expect to see the word code in yellow.
There isn't anywhere in there that has {{{ or << at the start of a line for any reason?
As a last resort you could try {{{ at the start and }}} at the end (again, each on their own line) to disable all format code parsing.
6 years, 4 months ago.
That's the normal cause of problems but in that situation I would expect to see the word code in yellow. http://www.templerun3.biz
