10 years, 3 months ago.
Setting the time from a 32 bit int causes CPU lockup
I'm attempting to simply set the time from a number, but when I do, the CPU locks up (a debug session stepping into set_time just freezes). The code I'm using is:
char *TmpPoint; time_t NewTime = strtoul(&TempData[2], &TmpPoint, 10); set_time(NewTime);
TempData is a char array { 'T', 'M', '1', '4', '5', '1', '3', '9', '6', '7', '7', '5', '\r', '\n' } which is correctly converted into 1451396775, so I can't see why such a simple operation would lock the CPU up. Using set_time() with a static number works fine. Any ideas/suggestions or is this CPU a write off?
What about the \r and \n are these being passed to set_time? I have had something similar, I could not see these on a printf.
posted by Paul Staron 29 Dec 2015I would call it really unlikely that it would be a CPU writeof. Can you do printf on the NewTime var, if you didn't already do so, to see what is in it.
posted by Erik - 29 Dec 2015I don't think it's caused by a stray \r or \n, neither can be represented in an int and strtoul() stops at the first non-valid number it finds, http://linux.die.net/man/3/strtoul : 'The remainder of the string is converted to an unsigned long int value in the obvious manner, stopping at the first character which is not a valid digit in the given base.'
I printed out the number both using printf and using print from gdb, both displayed just the (valid) number and no newline characters.
posted by Bob Seque 30 Dec 2015
