10 years, 3 months ago.
push and hold button?
Has anyone had any luck designing a push and hold button before? For example, pushing a button for less than 2 seconds does one thing but holding it for longer does something else..
I've been playing around with { Timer t; t.start() t.stop() } but it's a bit hit and miss so far. Also, once called, I cannot get timer to clear or reset to test the same thing again.
Any thoughts much appreciated.
hi Tom,
if you simply poll the signal, it might look something like this (caution: I did not compile this):
DigitalIn pbutton(p21);
Timer t;
int timeAtPress;
main() {
    t.start();
    bool pressed = false;
    while (1) {
        if (pbutton) {         // maybe if (!pbuttton) { if your signal is inverted.
            pressed = true;
            if (t.read() - timeAtPress < 2) {
                printf("held < 2 s\r\n");
            } else {
                printf("held > 2 s\r\n");
        } else {
            if (pressed) {
                pressed = false;
                    printf("released < 2 s\r\n");
                } else {
                    printf("released > 2 s\r\n");
            timeAtPress = t.read();    // keep resetting the start time when not held
