10 years, 3 months ago.
stm32L152, serial4 and serial 5
Hi to all i have this strange situation i write this code
//Serial pc(PC_10,PC_11); //Serial 4 TX, RX ko
Serial pc(PB_10,PB_11); //Serial 3 TX, RX //ok
//Serial pc(PC_12,PD_2); //Serial 5 TX, RX //ko
DigitalOut myled(LED1);
int i = 1;
pc.printf("Hello World !\n");
wait(1);
pc.printf("This program runs since %d seconds.\n", i++);
myled = !myled;
if i use Serial 3 all work well, if i use serial 4 or serial 5 don't work, can you give where is the error ?
can you help me?
best regards A.
If this is the case (viewing the serial output on USB), you can also add a wire from the SERIALn_TX pin you want to the CN3-RX connector. And one wire between the SERIALn_RX pin to the CN3-TX connector.
Hi Antoniolinux,
Are you trying to view this serial output through your serial console via the USB interface on the NUCLEO board?
If so then Serial 4 and 5 won't work because they aren't attached to the interface chip on the NUCLEO board. To read from Serial 4 and 5 you'll need an external serial adapter or another microcontroller/mbed.
Hope that helps, Brian
