10 years, 4 months ago.
OS Platform?
Hi
I trying to use this code for my undergraduate studies. I have compiled the code and everything seems fine until i run the program(nothing shows up!). i am using this on windows 8.1 and you have demonstrated this on mac, is this program OS specific or i can run on any operating system?
Dear Ebenezer,
I used this code successfully unfortunately with a software called Aeolus under GNU/Linux. You need use some MIDI software emulators. After some quick search this page [1] seems to be a good starting point or you can find some other software/hardware MIDI synthetizer.
Peter
Link: [1] http://www.musicrepo.com/testing-midi-device/
Thank you for the answer. I've installed the program, hopefully I should be able to test it out.
posted by Ebenezer Chikumbindi 30 Nov 2015
