10 years, 4 months ago.
Don't Work
Use the 'LPC1768' boards and gy-521(mpu-6050). Set up Using the GY-521 breakout board, I set ADO to 0 by grounding through a 4k7 resistor
and
Change
/* For LPC1768 board */ I2C i2c(p9,p10); setup i2c (SDA,SCL)
/* For NUCLEO-F411RE board */ static I2C i2c(D14,D15); setup i2c (SDA,SCL)
But don't work. (I AM 0x54 Could not connect to MPU6050 Check the connections... Calibration is completed. MPU6050 is initialized for operation..
_____________
Accelerometer(g)ax=0.000ay=0.000az=0.000
Gyroscope(deg/s)gx=0.000gy=0.000gz=0.000
_____________
Why take the 0x54 "WHOAMI" function? and why is the value of Acceleromater and Gyroscope zero?
