10 years, 3 months ago.
LPC1114.h file
I tried to find the LPC1114.h file because I want to look at the IRQ's.
I cannot find the file on the forum. Can someone point me in the right direction?
Thanks
Hi. You can find a CMSIS Cortex-M0 Core Peripheral Access Layer Header File for NXP LPC11xx Device Series (include LPC1114) here.
https://developer.mbed.org/users/mbed_official/code/mbed/file/9296ab0bfc11/TARGET_LPC1114/LPC11xx.h
Watarai-san, I published my program - maybe you can look at it. The mbed LPC1114 response to interrupts is very, very erratic. It keeps hanfing-up and only way out is to do a hardware reset.
https://developer.mbed.org/users/andrewcrussell/code/RC5_AndrewR/
I checked the hardware many times - so I think there is a problem with the IRQ defines.
posted by 19 Nov 2015
Do you put a pull-up register for the dp27? Since this pin is true open drain, DigitalIn::mode(PullUp) may not work.
posted by Toyomasa Watarai 22 Nov 2015Watarai San,
Yes, all the push button inputs have external pull up resistors.
Thanks for your question.
I think the issue is in the IRQ. Seems there is a problem - maybe in the register set-up file.
Regards
AndrewR
posted by Andrew Russell 22 Nov 2015
