11 years, 2 months ago.
ST Nucleo F103RB not recognized
I've received the ST Nucleo F103RB board and my windows 7 64b only detects an unknown device. I've installed the usb drivers and it doesnt seem to change anything.
Does anyone had the same problem and found a solution?
thx
7 years, 1 month ago.
Well, the information is correct. I found the post useful, but, nowadays, lots of users are complaining about an Error Code 0x9d". Click the link https://errorcode0x.com/fix-epson-printer-error-code-0x9d/ and know the steps for How To Recover the Epson Printer Error Code 0x9d issue.
6 years, 4 months ago.
Thanks for the solution provided. Even I am also facing the same consequences regarding the ST Nucleo F103RB. I have a small query regarding the Epson WF 3640 ADF. I am getting an error code of 0x97 in my printer. I have configured my printer settings and contacted the helpdesk. I have gone through their given instructions https://printerssupport.co/epson-wf-3640-adf-not-working/,but it's not working out. Guide us if we have missed out on anything.
Is the board still listed as an unknown device under Windows Device Manager ?
If yes, then the device driver did not install or is not the correct device driver for this board.
Perhaps related to the same issue we faced earlier this morning using another Nucleo board on Windows 8 64 bit. From where did you download the driver package ? We found the following to be correct for supporting our 64 bit version of Windows 8 (also will be correct to use for Windows 7 use):
http://www.st.com/web/catalog/tools/FM147/SC1887/PF260219?s_searchtype=partnumber
STSW-LINK009 ST-LINK/V2-1 USB driver on Windows XP (including WinUSB coinstallers)
Please review and test. If the above driver does not install then proceed to review the Device Manager -> select this unknown device -> post back the details for:
Details tab -> Hardware IDs (pulldown) = VID_ and PID_ for your attached board.
Update...
1) Is the cable applied to the Nucleo board a quality cable ?
2) Can you seat the cable onto another USB port ? Do you have access to another computer to test the same board ?
3) If using a USB hub, bypass and go direct to your PC.
The reading of USB IDs is a very fundamental part of the USB enumeration process. Device Manager should be able to read and list the IDs from the attached USB device. From the internet, the issue may be local to the Windows OS and perhaps can be resolved through a Microsoft service pack. However, before going this far, consider to test on a different box to see if the cable and board are confirmed operational and able to be detected by another box.
Please review this thread about Windows 7 & USB with UNKNOWN Device
Will check around the building to see if we have the same Nucleo board in the lab. If we do, will write back with our results.
On this note, the Nucleo is shipped with MBED mode (NUCLEO) and as an option can be used with the ST-Link mode. See the dual jumpers near the USB connectors.
If both jumpers are closed = MBED mode (NUCLEO).
If both jumpers are open, ST-Link mode.
Which mode is being tested now ? Consider to configure the opposite to test. Unplug -> change jumpers and reseat into the PC USB port on each attempt.
The idea is to confirm if the firmware is ok or corrupted. If the issue is still the same with either jumper configuration then review the idea of testing on another box so you can focus on the operating system / installation of the service packs.
Thank you for your answer. I first tried the "STSW-LINK008 ST-LINK/V2-1 USB driver on Windows Vista, 7 and 8" package and the one you told me. But my board is still not recognized and the red LED keeps blinking.
The Hardware IDS is USB\UNKNOWN (that's why I could nt use the solutions in the post of this morning)
Will it help?
Thx Gregory
posted by 03 Feb 2015I try my nucleo on different PC, with different mini usb cable. It still doesn't work. It may be corrupted. It's strange that on the ST site, windows 7 &8 drivers for this nucleo are no longer proposed for downloading, only XP... http://www.st.com/web/catalog/tools/FM116/SC959/SS1532/LN1847/PF259875 May I expect something new? However, thank you for your help. Gregory.
posted by 05 Feb 201510 years, 1 month ago.
Note that I had the same symptoms, tried on various PCs (Windows 7, Windows 10) and in the end it turns out it was down to the quality of the USB cable I was using. I tried two cables, no luck, only started working with a 3rd, better cable.
Thanks for your update. It is disgusting to hear that a cable can be the fault as it shows the poor quality of design and/or assembly of such cables being imported from shady vendors. The even more disturbing issue is that the cable is required to only support USB 2.0 or USB 1.1 specs which is very basic and a slow speed by today's standards and yet the cable was the fault. The never ending spiral of low cost sourcing for higher profit margins and a lower resale for the product in the eyes of the consumer. Very sad. Very happy to hear that you did not give up on searching for a proper resolution. End of my ranting :(
posted by 25 Feb 2016
