10 years, 5 months ago.
interrupt function questions
Why mbed compiler can not use the interrupt function? for example: int main() { uint8_t reserve[SIZE_STACK_FOR_IAP]; LPC_PINCON->PINSEL1 &= (0x00000003 << 16); LPC_GPIO0->FIODIR3|=0X01; LPC_GPIO0->FIOCLR3|=0X01; LPC_SC->PCONP|=0X00010000; printf("in RIT IRQ 1\n "); LPC_RIT->RICTRL=0X01; LPC_RIT->RICOMPVAL=384000000; LPC_RIT->RIMASK=0X00000000;
printf("in RIT IRQ 3\n "); NVIC_EnableIRQ(RIT_IRQn); LPC_RIT->RICTRL|=0X0A;
while(1) { printf("in RIT IRQ 5\n "); GPS_LEDFLASH(); wait(2); GPS_LEDOFF(); wait(2); deepsleep();
} return 0; }
void RIT_IRQHandler(void) { printf("in RIT IRQ\n "); LPC_RIT->RICTRL|=0X01; LPC_RIT->RICTRL&=0X07; GPS_LEDFLASH(); wait(2); GPS_LEDOFF(); LPC_RIT->RICTRL|=0X08;
the interrupt function can not enter
Just to improve the readability:
liu shuai's 1st code
   while(1)
      GPS_LEDFLASH();
      wait(2);
      GPS_LEDOFF();
      wait(2);
      deepsleep();
   return 0;
   GPS_LEDFLASH();
   wait(2);
   GPS_LEDOFF();
and
liu shuai's 2nd code
   while(1)
      wait(2);
   GPS_LEDFLASH();
   wait(2);
   GPS_LEDOFF();
posted by Miloje Zecevic 05 Nov 2015
sorry,After the issue of the code format will change。Yes, this is my code in the original format, what should I do to get the right to enter the interrupt handler。Now is the interrupt generated but can not enter the interrupt handler
posted by liu shuai 05 Nov 2015
Hi Liu,
if you want to use the predefined IRQ-Vector you have to declare it as extern for the compiler to see it:
extern "C" void RIT_IRQHandler(void) __irq {
   /* your handler code */
Otherwise you can use any void/void-function as handler by calling NVIC_SetVector:
void irq_handler(void) {
NVIC_SetVector(RIT_IRQn, (uint32_t)&irq_handler);
Best regards
Neni
You have solved my problem very well,Thank you very much@Neni,Also thanks to all the other people who helped me solve the problem.
posted by liu shuai 06 Nov 2015
First of all, please use <<code>> and <</code>> (on seperate lines) to make it readable.
Second, the mbed compiler can do interrupts, so you have an error in your code. Does your code run? Where does it fail? What did you try to debug it?
wait(2);
The code is compiled and debugged.Log “in RIT IRQ 5” can output 8times,That's 16 seconds. Then the program was dead. I think the interrupt response has been made.But the interrupt entry function is not correct, the interrupt handler function can not be executed correctly。 this is a "RIT interrupt"。What should I do in MBED to find the start function like LPC17XX.S,To confirm the interrupt handler name
