10 years, 4 months ago.
Pinmap mismatch
Hi guys, after compiling the example project without using the latest BLE API version, i have the following error on the console: pinmap mis-match
Do you know in which place I should configure the pins (I'm using the NUCLEO-F411RE and F401RE)
Thanks
Dear Leonardo,
I guess you are using an STM32 Nucleo F411RE. Keep in mind that the tested platforms for the X-NUCLEO-IDB04A1 are listed in the component homepage (https://developer.mbed.org/components/X-NUCLEO-IDB04A1). You can still use the STM32 Nucleo F411RE provided that you compile for STM32 Nucleo F401RE.
Kind regards
I know this post is older, but I found a fix in case anyone else runs into this problem getting it to run on the STM32F411RE. You need to define IDB0XA1_D13_PATCH in your project. That will map the SPI_CLK pin to PA_5 (D13) instead of PB_3 (D3), and that will resolve the pinmap mismatch. Cheers!
posted by Hushel Roberts 06 May 2017
