10 years, 5 months ago.
When I run a test with off-line mbed sdk , where to see the log printed.
Hi, everyone,
I am learning mbed, this question confuse me a lot.
When I run a test , such as "MBED_A6", where can I see the log.
MBED_HOSTTEST_TIMEOUT(10);
MBED_HOSTTEST_SELECT(default_auto);
MBED_HOSTTEST_DESCRIPTION(DigitalInOut);
MBED_HOSTTEST_START("MBED_A6");
bool check = true;
d1.output();
d2.input();
d1 = 1;
wait(0.1);
if (d2 != 1) {
printf("MBED: First check failed! d2 is %d\n", (int)d2); //where to see this log
check = false;
Thank you very much!
Usually to the USB/Serial COMx: port see:- https://developer.mbed.org/handbook/SerialPC
Setting you will need for your host PC (Use Application such as Putty Hyperterminal etc.,) Default is:- 9600Baud 8Bit 1Stop bit No Parity no handshaking
posted by Martin Simpson 27 Oct 2015
