11 years, 1 month ago.
Can I create a master and slave in one nRF51822 mbed platform(like HRM1017)?
Dear team,
Just want to confirm does Bluetooth 4.0 spec prohibit a BLE device from being both a slave and a master at the same time.
If no limitation, have Nordic already offered a single stack for nRF51822 capable of acting both as a master and a slave?
We would like to create a BLE bridge device to connect the smartphone and BLE sensor device, so need your help to clarify if it is possible.
Phone(Master)>BLE>Bridge Device(Master/slave)>BLE>Sensor Device(slave) and it will be fine if Bridge Device could not being both master and slave at same time, but can switch dynamically with one firmware.
Best Regards, Xinbai
Bluetooth Low Energy (a.k.a Bluetooth LE, BTLE, Bluetooth Smart)
Actually, you should be able to run as both a "server" and "client" in the same connection at the same time with S110, while being a "peripheral".
With the S120, you can be a "central" and connect to multiple "peripherals" (up to 8 IIRC).
With the S130, you get to be a central (but with a smaller number of peripherals) and/or peripheral.
Other SDs (soft devices) are available that include ANT as well as BLE.
All of this is from memory. I've done a lot of BLE work with the nRF51822, but only as a peripheral server. So check the datasheets.
HTH,
Mike
Nordic has three stacks for nRF51822.
