13 years ago.
How reset the Ticker?
Hi, My test code work good in beginning but after 10 minutes my time_impulse become unstable. if i push on reset button to restart progam and it become stable again. What can be the cause? I think should be the timer. If yes, how can i reset the Ticker? Thank you, Vilounha
int start=0,count=0;
char command=0;
Ticker tick;
InterruptIn event(PTD6);
Serial pc(NC,USBRX);
DigitalOut lamp1(PTB8);
void time_impulse() {
    if(start){
        if((count==command)||(count==command+64)){
            lamp1=1;
            wait_us(5);
            lamp1=0;
        else
            lamp1=0;
        if(count>128){
            start=0;
        else count++;
// sync with 60Hz zero-crossing AC Line
void zero_impulse() {
        start=1;
        count=0;
    tick.attach_us(&time_impulse,130);//1/60./128.= 0.00013020
    event.rise(&zero_impulse);
    while(1){
        command=pc.getc();
        //pc.putc(command);
13 years ago.
Hello Vilounha,
I would guess the issue could be, you are writing the variable start and count in both functions. They are ISRs, if I understand this correctly, and one could have a higher priority. I am not sure how the MBED is configured. But I guess the interrupts can be nested. So the ISR with the higher priority changes a value which gets overwriten as soon as the ISR ends. e.g.
if(count>128){
zero_impulse() {start=1;count=0;}
start=0; }
Something like that would explain why you have an issue after some time. This is a matter of probability.
Best Regards
Klaus
Hi Klaus, I will look at ISRs priority. How to setup a priority of ISRs? Thank you, Regards, Vilounha
posted by Vilounha Phanalasy 16 Mar 2013
13 years ago.
Try
volatile int start=0,count=0;
volatile char command=0;
Best regards
Neni
