10 years, 5 months ago.
RPC for RawSerial hangs after sometime
I have added RPC support on FRDM K64 target so that i can communicate from PC using python.
I have K64 communicating with BT chip over UART (for this I have to use RawSerial as Serial had problems where it hangs due to mutex calls from C library). This is on UART0.
From python script I am trying to call putc and getc. It works for some time but later my mbed target gets hanged in serial_getc() function and never comes out of this.
Note: the hang is not seen when I disable my debug serial terminal which is on UART3. It is only when the debug terminal is on the mbed hangs in serial_getc().
Code snippet on mbed:
mbed k64 code
Serial pc(PTC17,PTC16);
main()
EthernetInterface eth;
if(eth.init())
pc.printf("Error while initializing the ethernet interface.\n");
return -1;
if(eth.connect())
pc.printf("Error while starting the ethernet interface.\n");
return -1;
pc.printf("IP Address is %s\n", eth.getIPAddress());
RPC::add_rpc_class<RpcRawSerial>(); // Note: I added RPCRawSerial support in RPCclasses.h
RpcRawSerial bt(PTB17,PTB16,"btuart");
TCPSocketServer server;
server.bind(ECHO_SERVER_PORT);
server.listen();
while (true) {
pc.printf("\nWait for new connection...\n");
TCPSocketConnection client;
server.accept(client);
pc.printf("Connection from: %s\n", client.get_address());
char buffer[256];
while (true)
int n = client.receive(buffer, sizeof(buffer));
if (n <= 0) break;
buffer[n] = '\0';
pc.printf("Received message from Client :'%s'\n",buffer);
RPC::call(buffer, outbuf);
pc.printf("Result got =%s\n", outbuf);
client.send_all(outbuf, n);
if (n <= 0) break;
client.close();
return 0;
I tried even using the RPCSerial instead of my own RPCRawSerial, but the result is the same. Hangs in serial_getc.
Only after completely disabling the debug UART it works fine.
Any clue on Why there is a hang when debug is enabled ?
mbed k64 code
My RPC raw Serial class is as below
class RpcRawSerial : public RPC {
public:
RpcRawSerial(PinName a0, PinName a1, const char *name=NULL) : RPC(name), o(a0, a1) {}
void baud(int a0) {o.baud(a0);}
int readable(void) {return o.readable();}
int writeable(void) {return o.writeable();}
int putc(int a0) {return o.putc(a0);}
int getc(void) {return o.getc();}
int puts(const char * a0) {return o.puts(a0);}
virtual const struct rpc_method *get_rpc_methods() {
static const rpc_method rpc_methods[] = {
{"baud", rpc_method_caller<RpcRawSerial, int, &RpcRawSerial::baud>},
{"readable", rpc_method_caller<int, RpcRawSerial, &RpcRawSerial::readable>},
{"writeable", rpc_method_caller<int, RpcRawSerial, &RpcRawSerial::writeable>},
{"putc", rpc_method_caller<int, RpcRawSerial, int, &RpcRawSerial::putc>},
{"getc", rpc_method_caller<int, RpcRawSerial, &RpcRawSerial::getc>},
{"puts", rpc_method_caller<int, RpcRawSerial, const char *, &RpcRawSerial::puts>},
RPC_METHOD_SUPER(RPC)
return rpc_methods;
static struct rpc_class *get_rpc_class() {
static const rpc_function funcs[] = {
{"new", rpc_function_caller<const char*, PinName, PinName, const char*, &RPC::construct<RpcRawSerial, PinName, PinName, const char*> >},
RPC_METHOD_END
static rpc_class c = {"RawSerial", funcs, NULL};
return &c;
private:
RawSerial o; //Instead of Serial, i made it RawSerial
-yk
Any input on why a hang (serial_getc) when I use the standard RPC serial along with the serial debug port. It does not hang when I do not use my serial debug port. I want both enabled as part of my project.? Any approach I should take to debug this problem ? - YK
posted by yogesh kulkarni 27 Oct 2015
