10 years, 6 months ago.
ports of nucleo board
hello i have some questions about the ports of the nucleo board l053r8.. the first one is how many ports has the nucleo board?.. the second is how to use PortIn? for example i want to use only 3 pins of the port C as in and the other i dont want to use them at all... what would be de code for this?..
and number 3: how can i use the instruction if when i want to read the entire port and do something only if some pins of the port are high or low...
thank you so much!!
