10 years, 5 months ago.
How do I use serial write for uint8 buffer array?
I cannot compile if I use serial write(). It comes up with error: virtual ssize_t mbed::Stream::write(const void*, size_t)' is protected. Here is the function:
void serialWrite(Serial* _fd, uint8_t* buf, uint8_t len)
int remain = len;
int offset = 0;
while (remain > 0)
int sub = (remain >= 8 ? 8 : remain);
_fd->write(buf + offset, sub);
wait(0.01);
remain -= 8;
offset += 8;
return;
The passed array like uint8_t cmd[] = { 0xAB, 0, 0xAC, 0xBC, 0xFE, 0x45, 0x68, 0xEA, 0x85, 0xBC, 0x62};
Develop env.: WIN7, Eclipse, Cross ARM GCC.
How do I fix it? Thanks.
That is not the error I would have expected you would get, since as far as I am aware serial write function does not exist for the LPC1768. All those asynchronous functions are only available on a few Silicon Labs boards, and just polluting the documentation for all other platforms. One option you have is simply using putc on each byte you want to send in a loop.
If you do want to send it asynchronously you can have a look at either MODSERIAL of BufferedSerial libraries for your device.
