10 years, 6 months ago.
PCB Design
Dear,
I am designing the PCB to plug the board LPC1768, I have grounded all pins which I do not use, do you think it Is a good idea?, should I configure as a digital input and set up to (0)?
I look forward to hearing from you soon
Regards
Antonio
mbed Development team
I'd leave them no connect. That way nothing blows up if some software is accidentally installed on the mBed that tries to use those pins as outputs.
It also means that if you want to use the pins at a later date you can strap wires to them.
Thank u
posted by antonio mbed 04 Nov 2015
