10 years, 5 months ago.
read_u16 on the Nucleo F401- least significant nibble equals the most significant nibble?
The code below is a simple demo of reading the ADC from pin A0 on the Nucleo F401.
As I increase the voltage on pin A0, so I surprised to see non-zero values in bits 0..3 I was expecting zeros. I understood this device to have a 12 bit ADC, and that the bits should be shifted left 4 bits for cross-platform compatibility.
However, they are either zero or equal to bits 12..15
It's easy to mask out, but I don't like not understanding the cause.
Can anyone explain why this is happening.
Nick
simple ADC example
//Function prototype
void doSample1Hz();
//Global objects
Serial pc(USBTX, USBRX);
AnalogIn POT_ADC_In(A0);
DigitalOut led(LED1);
//Shared variables
volatile static unsigned short sample16 = 0;
//The ticker, used to sample data at a fixed rate
Ticker t;
//Main function
    //Set baud rate to 115200
    pc.baud(115200);
    //Set up the ticker - 1Hz
    t.attach(doSample1Hz, 1.0);
        //Sleep
        sleep();
        //Display the sample in HEX
        pc.printf("ADC Value: %X\n", sample16);
    } //end while(1)
} //end main
//ISR for the ticker - simply there to perform sampling
void doSample1Hz()
    //Toggle on board led
    led = !led;
    //READ ADC as an unsigned integer - store in static global variable
    sample16 = POT_ADC_In.read_u16();
If the 4 least significant bits were always 0 then the range would be from 0x0000 to 0xfff0, that's not the full range for a 16 bit output. In order to use the full range the value should go from 0x0000 to 0xffff. Copying the 4 most significant bits into the 4 least significant bits is a simple way to achieve this in a nice linear way that avoids any big jumps in the output.
posted by Andy A 17 Sep 2015
Some years ago I worked as a DSP engineer and I never encountered this technique. Thanks for highlighting it.
posted by Nicholas Outram 17 Sep 2015
If you inspect your target's mbed-src, specifically analogin_api.c, you'll see the 12 to 16 bit conversion:
uint16_t analogin_read_u16(analogin_t *obj) {
    uint32_t value = adc_read_u32(obj);
    return (value << 4) | ((value >> 8) & 0x000F); // 12 bit
Thus the 12 bit value is normalised to the full 16 bit scale.
