10 years, 6 months ago.
Ublox C027 Exported project, No Reply from Modem
When i try online editor and write bin file to MBED drive work like a charm. But when I export the code for Lpcxpresso IDE or IAR and compile the code... and write to device.
Writing method I try to write the bin MBED drive as usual also I tried to write binary [Program Flash button] in Lpcxpresso
I got this error.
Modem::wakeup  0.276 AT send 4 "AT\r\n" 1.580 AT send 4 "AT\r\n" 2.883 AT send 4 "AT\r\n" 4.186 AT send 4 "AT\r\n" 5.489 AT send 4 "AT\r\n" 6.792 AT send 4 "AT\r\n" 8.095 AT send 4 "AT\r\n" 9.398 AT send 4 "AT\r\n" 10.701 AT send 4 "AT\r\n" 12.005 AT send 4 "AT\r\n" No Reply from Modem
I checked the LISA-U module <->MCU RX TX pins. there is no data outcoming. when the code compiled in Mbed online I can see AT commands on those pins.
do you have an Idea how to make it work? --------------------
Version LPCXpresso v7.9.0 [Build 455] [2015-07-23] IAR 6.3
9 years, 11 months ago.
i also have the same problem. The other example, TransparentModem, doesn't work too, either in lpcexpresso or keil.
10 years, 5 months ago.
I have the same problem. Did you already found a solution?
Hi Greenteam,
it might be a good idea to check your flow control settings on AP.
Regards, Jaka
9 years, 5 months ago.
I also have the same problem.
Problem still continues for LpcXpresso
Can
