10 years, 7 months ago.
Software Reset
is there a command which causes a software reset?
I would like to produce a reset with a if-loop.
z=z++;
myled = 1;
wait(0.2);
myled = 0;
wait(0.2);
if(z==10){
SOFTWARERESET
Is there a command?
Thank you for help,
Marvin
Yes: NVIC_SystemReset().
I use mbed_reset() (with a C declaration : extern "C" void mbed_reset(); )
To note the difference: The one I mentioned will reset only the target and works always on each target.
This one works only on original two mbeds (which the poster has, so that's fine), and performs reset by asking the interface chip to do a reset. This will also load a new binary file if you drag and dropped it on the disk.
posted by Erik - 31 Aug 2015
