10 years, 3 months ago.
Can anybody successfully compile any mbed DISCO-F746NG project?
Hi all, - I could successfully add a DISCO-F746NG platform to my mbed projects, - I see at http://www.st.com/web/en/catalog/tools/FM147/SC1887 that MBED-F746-DK support is turned "Active" and it is linked to mbed site, - I see under "mbed-src" that the target "TARGET_DISCO_F746NG" should be already supported by the mbed library.
Nevertheless if I try to compile a sample project (e.g. simple "Hello World"), I get only these messages: "Error: The build system did not finish successfully." ErrorNo=-230 "Info: Unable to download. Fix the reported errors..." But, it won't be mentioned, what is the reason of the compiler failure.
What do I wrong? -Marcin
Try the offline compiler (STM32 System Workbench) and add the latest libraries from mbed repo. Builds perfectly for me
posted by Habibur Rahman 26 Sep 2015
I was just able to use the mbed library and compile the LCD demo. Most of the stuff I need to use seems to be there except the Ethernet. There is an Ethernet api but the basic functions of read / write do not have any tcp handle support so I don't even know how you are suppose to open a tcp socket for listening for connections.
posted by James Armstrong 15 Oct 2015
It's not quite ready yet, they were a bit previous to add it to the platform page without it being finished. Bit naughty really.
Any update on support?
posted by Patrick McNamara 09 Jun 2016
