10 years, 8 months ago.
could not put SD card in to SPI idle state ,
Hello, I'm using nucleo-L053R8. When trying to store sensor values, I'm getting above problem.
Didn't get a response from the disk , Set 512-byte block timed out
Do you get the same error without a card fitted? Most of the time when I see that error it's because I forgot to put the card in the socket.
If removing the card doesn't change the error then check your connections and the pin selections.
