10 years, 6 months ago.
DCMI on the Seeed Arch Max
Does anybody know if DCMI works on the Ach Max? I have been trying to get it working, it mostly hangs when the DCMI interrupt is enabled. I have used STMCube to generate the driver. Unless someone can come up with a definitive answer, I will re-write using the STM Lib and not mbed, to see if the mbed lib is causing problems.
Did you define the interrupt handler correctly? I don't think the mbed lib itself can cause the issue, but while not 100% sure, I believe the mbed STM drivers included were slightly modified to make them not use anymore the System Tick timer (which was a bad decision in the first place to use). That could be related to it, but I am not sure at all if this is actually the case!
posted by Erik - 15 Aug 2015
Thanks Erik, your comment made me think. Even though I had the interrupt calls in my program they were being ignored for some reason, so I used the stm32f4xx.it.c and h files, now I can see the interrupt callbacks working.
posted by David Fletcher 16 Aug 2015
