11 years, 2 months ago.
LocalFileSystem
i know there are many many posts on localfilesystem problems and how tos, but i did not find an answer...
system: mbed lpc1768
my problem: i wanted to read a file from the mbed space that shows up when connected via usb (where the .bin goes ant the mbed.htm is).
following code ends in error:
LocalFileSystem local("local");
printf("File Parsing:\r\n");
    FILE *fp2 = fopen( "/local/registers.txt", "r");
    printf("Loading file:\r\n");
    if ( fp2 == NULL ) {
        error("Could not open file for read operation.\r\n");
so i tried to start at the beginning and implemented the example from the localfilesystem: localfilesystem example copied to compiler:
LocalFileSystem local("local");               // Create the local filesystem under the name "local"
    FILE *fp = fopen("/local/out.txt", "w");  // Open "out.txt" on the local file system for writing
    fprintf(fp, "Hello World!");
    fclose(fp);
i am connected to the mbed via usb, i see the device and the bin but the out.txt never shows up.
i also tried another example:
FILE *fp = fopen("/local/test.txt", "w");
    fprintf(fp, "Hello file system!\n");
    if ( fp == NULL ) {
        error("Could not open file for write operation.\r\n");
    fclose(fp);
which throwed no error but showed no file. after some restarts and refreshes i saw test.txt and TEST.TXT but neither file was accessibl. windows throwed an access error message. When i deleted it and loaded blinky demo with only led blinking the files always reappeared.
i flashed the newest firmware again to the mbed and now the files are gone but i still cannot read or write to files.
what am i missing?
Hi Jörn,
You are using long file name for reading file. It could be fine if you use "8.3" format file name. The name should be 8 characters or less and suffix should be 3 chars or less
If you try "registrs.txt" instead of "registers.txt", it will be fine ;)
hi and thank you for your answer.
i tried the write example again and i figured out that i have to unplug the mbed and have to plug it in again, only then the out.txt shows up.
i changed my read to an 8.3 format and now it seems to work.
thanks for help!
posted by Jörn K. 14 Jan 2015
