11 years, 2 months ago.
How to construct a library with digital out pins.
I want to construct a library (properly for Mbed) that drives a LCD display using 3 DigitalOut pins.
I can add my code in later but not sure of the correct way to set this out and define the pins in the constructor. I'm using the following files:
main program
#include "9digitLCD.h"
9digitLCD lcd(PTC0,PTC1,PTD6); // WO, CS, DATA
while(1){}
9digitLCD.h
class 9digitLCD : public Stream {
public:
9digitLCD(PinName WO, PinName CS, PinName DATA); // Default constructor
private:
DigitalOut WO;
DigitalOut CS;
DigitalOut DATA;
9digitLCD.cpp
9digitLCD::9digitLCD(PinName WO, PinName CS, PinName DATA) : _WO(pin),_CS(pin),_DATA(pin){initialise_display();}
Can anyone help just to get me started with this Generally I chop and change existing libraries, but its about time I do my own.
Many thanks
Paul
Hi, Paul-san,
Following is my trial.
Typing 0 from the terminal turn LED to white, 7 to dim...
#ifndef _RGBLED_H_
#define _RGBLED_H_
class RGBLED {
public:
RGBLED(PinName RedPin, PinName GreenPin, PinName BluePin) ;
~RGBLED() ;
void write(int value) ;
int read(void) ;
#ifdef MBED_OPERATORS
/** A shorthand for write()
RGBLED& operator= (int value) {
write(value);
return *this;
RGBLED& operator= (RGBLED& rhs) {
write(rhs.read());
return *this;
/** A shorthand for read()
operator int() {
return read();
#endif
private:
DigitalOut _R ;
DigitalOut _G ;
DigitalOut _B ;
#endif /* _RGBLED_H_ */
#include "RGBLED.h"
RGBLED::RGBLED(PinName RedPin, PinName GreenPin, PinName BluePin) : _R(RedPin), _G(GreenPin), _B(BluePin)
// for the initial value, I want dim all three
_R = 1 ;
_G = 1 ;
_B = 1 ;
RGBLED::~RGBLED()
// same reason with the constructor
_R = 1 ;
_G = 1 ;
_B = 1 ;
void RGBLED::write(int value)
_R = (value >> 2) & 0x01 ;
_G = (value >> 1) & 0x01 ;
_B = value & 0x01 ;
int RGBLED::read(void)
int result ;
result = 0x4 * _R + 0x2 * _G + _B ;
return( result ) ;
#include "RGBLED.h"
RGBLED rgbled(PTB18, PTB19, PTD1) ; // for FRDM-KL25Z
int value ;
printf("> ") ;
scanf("%d", &value) ;
rgbled = value ;
moto
Thank you Motoo :) I will use this example to build my code and let you know how I get on.
edit....
That worked fine, all done now, here is the result:
https://developer.mbed.org/users/star297/code/HT1621_16seg_LCD/
I took out the "~ RGBLED() ;"
Not sure why or if this is needed or why it would be needed, something to do with 'Bitwise NOT' but I can't find an example explanation for use in constructing a library.
posted by 14 Jan 2015
