11 years, 2 months ago.
Need help with CAN Bus code
Hello. I have tried several of the mbed CAN Bus examples without success. I simply want to send a byte from the CAN transmitter. The byte comes from a counter in the loop that should send a new CAN message every 300 msec. (I printed info to TeraTerm to test the code and commented out the printf statements for a real run. See sample at the end of this post.)
Here's the simple code I created:
DigitalOut led2(LED2);
DigitalOut led4(LED4);
CAN can1(p30, p29); //CAN Transmitter
char counter = 0;
pc.baud(9600);
can1.frequency(125000);
can1.reset();
while(1)
//pc.printf("In while loop\n\r");
led2 = !led2;
wait(0.3);
//pc.printf("Sending\n\r");
if (can1.write(CANMessage(0x139, &counter, 1)))
led2 = !led2;
//pc.printf("Message sent: %d\n\r", counter);
counter++;
else
led4 = !led4;
I do see a burst of pulses every 300 msec, but they look nothing like a CAN message. I see a long logic-0 pulse followed by 15 shorter logic-0 pulses in each "message." My logic-analyzer bit rate and the bit rate in the code match. I can see the same signals on a scope. I've also included the terminal output that shows what the program produces when I use the print statements, so I know the counter increments, although I don't see CAN messages.
I'm lost at this point and would appreciate help. Thanks.
Message sent: 30
In while loop
Sending
Message sent: 31
In while loop
Sending
Message sent: 3 2 In while loop
Sending
etc...
Have a look at this AP:
http://www.mikrocontroller.net/attachment/28831/siemens_AP2921.pdf
This is the simplest way to comunicate on CAN bus without a transciever (TJA1040 or similar).
You should use both CAN channels on the MBED and try to send from node 1 to node 2. Otherwise the controller will abort the transmission. You can check this with rderror() and tderror(). If every thing is OK, these two counters equals zero, otherwise they count faults on the bus.
Have you wired up the CAN driver and terminating resistors. CAN is a multi masterbus and it checks to see if the signal on the bus matches the transmission and aborts when this is not the case. That analyser picture looks like aborted messages. When the driver is missing you could try a resistor between tx and rx.
I get the same output signal when I run the AIN2CAN program.
posted by Jon Titus 11 Jan 2015Jon
