11 years, 2 months ago.
else if
hi I have code my programme but there is an error that I appreciate anybody helps me. It says that 'else' need a statement while i have put the statement there. here is the code:
  else {
            lcd.clear();
            lcd.refresh();
            time_t seconds = time(NULL); // get current time
            // format time into a string (time and date)
            strftime(buffer1, 14 , "%X ", localtime(&seconds));
            strftime(buffer3, 14 , "%D ", localtime(&seconds));
            // print over serial
            // serial.printf("Time = %s\n",buffer1);
            sprintf(buffer2," %s",buffer1);
            lcd.printString(buffer2,0,2);
            lcd.printString(buffer3,0,3);
            if (setTimeFlag) {   // if updated time has been sent
                setTimeFlag = 0; // clear flag
                setTime();       // update time
            //wait(0.2);           // stops the screen from flashing
Edit by 0xc0170: please use '<<code>><</code>>' syntax for code snippets, thanks
what's before else { ?
posted by Martin Kojtal 11 Jan 2015
there were 2 'if' i changed them to 'while' and removed the else and it works but doesn't show another variable. I am using mbed NXP LPC1768 wit TMP102 and a screen. now the error is that it doesnt show the temperature.thanks
posted by Mahmood Parsi 11 Jan 2015
Have you closed the initial 'if' with a bracket., need to see the rest of the code really.
no worries. the problem was for not having 'buttonB.mode(PullUp);' at the begging, thanks anyway during using the button
