10 years, 7 months ago.
Should i2c_slave_receive return ACK?
I'm trying to port mbed to a new target platform. I'd like to clarify whether the i2c API i2c_slave_receive() is expected to return ACK or not? If not, when is the device expected to return ACK for an address match? Before the next read/write?
Yes the slave will send ACK or NACK. There is a number of sources of information referring to the specification of I2C do a web search. i2c.info, i2c-bus.org and NXP to name a few.
posted by David Fletcher 13 Aug 2015
I suspect you mistyped i2c_slave_receive? As this function has this declaration:
/** Check to see if the I2C slave has been addressed.
 *  @param obj The I2C object
 *  @return The status - 1 - read addresses, 2 - write to all slaves,
 *         3 write addressed, 0 - the slave has not been addressed
int  i2c_slave_receive(i2c_t *obj);
No, sorry for the misunderstanding! I asked whether we should return ACK (to the actual master device) in the implementation of i2c_slave_receive, not about the return value of function.
posted by Vimalraj Rajashekharan 13 Aug 2015
Ok I see your point. I havent used yet i2c slave. From looking at sources quickly now, looks like most of the implementation just reads registers to get a status and return it.
posted by Martin Kojtal 13 Aug 2015
Okay Martin! I'll proceed with the implementation as if it's just a status check only. If you get more info, please let me know. Thank you!
