11 years, 2 months ago.
Any example code?
Hi, I tried this, maybe I'm doing it wrong :)
It doesn't get past pc.printf("after reset\n");
Update: I used
Serial pc(USBTX, USBRX); ESP8266_WebServer ESP_WS(&pc);
And I see requests on my pc terminal, but it hangs inside functions due to not having a timeout
#include "ESP8266_WebServer.h"
Serial esp(PA_11, PA_12);
ESP8266_WebServer ESP_WS(&esp);
pc.baud(115200);
esp.baud(115200);
wait(0.5);
pc.printf("before reset?");
ESP_WS.ResetModule();
ESP_WS.Initialize();
pc.printf("initialized?\n");
Hi Radu
This library is not quite ready for public consumption yet, and is primarily used in our WiFi Lamp project. It still has a few kinks and quibbles, and thats also why I haven't publicly listed it yet,
Nonetheless, here is a bit of code which should get you started
#include <string>
//#define DEBUG_WIFI
Serial wifiSerial(PA_11,PA_12);
Serial pc(USBTX,USBRX);
ESP8266_WebServer server(&wifiSerial);
void rxint(void) {
server.rxint();
pc.baud(115200);
wifiSerial.baud(115200);
wifiSerial.attach(&rxint);
#ifdef DEBUG_WIFI
server.debugSerial = &pc;
pc.printf("Debug WiFi Enabled!\r\n");
#endif
wait_ms(1000);
pc.printf("Hardware Reset WiFi...\r\n");
server.ResetModule();
std::string fwVer = server.GetFirmwareVersion();
pc.printf("ESP Firmware Version: %s\r\n", fwVer.c_str());
pc.printf("Starting Web Server...\r\n");
server.Initialize();
pc.printf("Done\r\n");
int opMode = server.GetOperatingMode();
pc.printf("Operating Mode: %s(%d)\r\n", opModes[opMode], opMode);
if( (opMode & OPMODE_STATION) ) {
pc.printf("Waiting 5 secs for join to WiFi Network...\r\n");
wait_ms(5000);
std::string stationMAC = server.GetStationMAC();
std::string stationIP = server.GetStationIP();
std::string ssid = server.GetStationSSID();
pc.printf("Station MAC: %s, Station SSID: %s, Station IP: %s\r\n", stationMAC.c_str(), ssid.c_str(), stationIP.c_str());
if( (opMode & OPMODE_SOFTAP) ) {
std::string apMAC = server.GetAPMAC();
std::string apIP = server.GetAPIP();
pc.printf("SoftAP MAC: %s, SoftAP IP: %s\r\n", apMAC.c_str(), apIP.c_str());
while(true) {
ESP8266_WebRequest* request = server.GetRequest();
if( request != NULL ) {
pc.printf("HTTP %s %s\r\n", request->Method.c_str(), request->URI.c_str());
if( request->URI == "/" || request->URI == "/index.html" ) {
server.SendReply(request->LinkID, "<html><body>It Works!</body></html>", mimeHTML, 0);
} else {
server.Send404Error(request->LinkID);
pc.printf("\r\nHTTP Reply Sent\r\n");
delete request;
Information
You can uncomment the DEBUG_WIFI define to make the library print out a lot of debugging information.
Warning
This sample requires about 33kb of Flash, and 8kb of RAM. Any hardware with less RAM or Flash will not work.
Hi and thanks, I was reluctant at first to ask, considering it was not public, but I just had to :D I'm packed with a Nucleo F411RE. I'll keep you posted.
Well, as a good news it works.I need to update my firmware to support the new CIPSTA commands
posted by 12 Jan 2015All good. A bit of publicity will force me to bring it up to standard :-)
BTW, I have found this firmware to be quite stable and seems pretty official https://github.com/espressif/esp8266_at
posted by 13 Jan 201511 years, 2 months ago.
As I and other have found, the recent ESP8266 modules are 9600 buad, there is no auto-baud so you may want to try this setting.
Hi Paul
A lot of recent ESP8266 modules are very mixed in regards to their baud rate, and I have not been able to determine a definite guide to figuring it out. My own module was first 9600, but when I upgraded it to the latest Espressif AT firmware, it changed to 115200 https://github.com/espressif/esp8266_at
