11 years, 1 month ago.
About installing gcc4mbed
I think I already installed gcc4mbed to my mac pc according to this web site "https://github.com/adamgreen/gcc4mbed#quick-start"
And also I installed CDT GNU Cross Development Tools from eclipse's install new software page.
But I have two different situation. First one, in Toolchain for Indexer Settings , I couldnt see ARM Mac OS X GCC (Sourcery G++ Lite)
second one about Build (Incremental Build) from all to all deploy GCC4MBED_TYPE=Debug I couldnt see this item GCC4MBED_TYPE=Debug.
I couldnt be sure about I installed gcc4mbed correctly. How can I be sure about that ?
Hello Kagan,
When you installed gcc4mbed it should have automatically done a clean build and would have generated an error if anything had gone wrong. The install process should have created a mac_install.log in the root gcc4mbed subdirectory. You could check it for any errors.
The install process also generates a BuildShell script in the gcc4mbed subdirectory. If you run that script then you will have a Terminal window that is able to build the gcc4mbed samples. With this terminal you should be able to go into the samples directory and issue a make clean-all all to build all of the sources again to make sure that it is able to successfully build things outside of Eclipse.
Even though I helped document the steps to install Eclipse, I don't have much experience with it myself.
I hope that helps,
Adam
10 years, 10 months ago.
Even I am facing the same issue as Kagan. It does not work from the terminal either :( @Kagan - were you able to solve it ?
