11 years, 2 months ago.
Databus pin order
Hello Todor, I'm finally getting around to using your library and want to check that the data bus pin order is DB0 to DB15, I'm not sure as your pin numbers in the ssd1289 example count the pins down. Cheers Mike
Hi Michael,
I'm not familiar with this code, but I found this SSD1289 details.
Is that what you are looking for?
