11 years, 2 months ago.
Compile with Eclipse?
Hi, how can I create .bin-files in offline-mode? I´ve installed eclipse and arm-plugin. I´ve also installed arm-tools like make (win7).
I´m unable to copy example vom online-compiler (export-function) and using eclipse in offline-mode. Exists there other users having experiences in using eclipse with special plugin for ST Nucleo F411RE?
Affordable and flexible platform to ease prototyping using a STM32F411RET6 microcontroller.
10 years, 11 months ago.
i don't know if you have your answer but you could read it from here
http://hotboards.org/index.php/es/blog/20-spanish/blog/st/102-programando-con-el-bootloader
but is in Spanish
Just export to GCC ARM, create a makefile project, import your sources, set debugger (also GCC enviroment + make), and you should be albe to build it. There are articles on the web. On my webpage I believe I published one how to, for one of FRDM targets.
0cx0170
