11 years, 3 months ago.
stuck on btle_init>>
I imported this program and on running , my terminal is stuck on ->
Initializing btle_init>>
... nothing after that ...
Any idea ?
Thanks. -Vijay
I know this post is 7 months old, but it seems I am stuck with the same problem. Connecting Pin11 and Pin31 on CN10 (double checked its not CN7) as shown didn't change anything. Help please.
I am using NucleoF411RE board with BlueNRG shield X-NUCLEO-IDB04A1.
posted by Aravind Parvathala 10 Aug 2015
Hi Aravind,
if have a NUCLEO-F411RE with Pin11 and Pin31 shorted, you can't use the LED on the Nucleo and the BlueNRG shield at the same time. The reason is that in such a configuration, the LED pin and the SPI clock are shorted and cannot be controlled successfully at the same time.
Hope that helps, Antonio.
posted by Antonio Vilei 01 Oct 2015
Hi
Use a jump wire to connect pin 11 to pin 31 of the CN10 or on the BlueNRG shields (Remove R10 and assemble R11)
/media/uploads/sjallouli/nucleo_jump_wire.jpg Thank you.
hello,
I am getting randomly this error -
btle_init>> AddService(): Type:0
added servHandle handle =0
Char Properties 0x10
Setting up Gatt GATT_INTIMATE_APPL_WHEN_READ_N_WAIT Mask
added bleCharacteristic handle =17757
updating bleCharacteristic charHandle =17757, corresponding serviceHanle= 0
Error while updating characteristic.
Please clarify
posted by Vijayaraghavan Narayanan 22 Dec 2014
Hi Vijay,
We still don't have a clear answer on that.
Sorry for that.
Slim.
posted by slim.jallouli@... 22 Dec 2014
You get Error 17757 if you mix up CN7 and CN10 by connecting the jump wire between pin 11 and pin 31. Be care that the ST-Link module on the attached picture looks to the right.
posted by Alexander Eberhardt 03 Jul 2015
