11 years, 4 months ago.
KL25z 32 kb and 64 kb versions
Has anyone had any luck with programming the kl25z chips that have less flash, such as the MKL25Z32VFM4 or the MKL25Z64VFM4 using the swd outputs on the kl25z development board?
You can only program the same Target that is on the FRDM board. When downloading the SDA MCU will check the Target MCU type number and then start programming if it sees the correct MCU.
