11 years, 4 months ago.
Flash overflows with GCC export by adding UART
Hi, I've been using the MBED LPC1768 with the offline GNU toolchain (on Windows) for some time now and recently I switched to compiling for the FRDM-KL05Z.
A basic blinking led is not a problem. However, the second I add a uart port the linker complains about overflowing the flash.
-eabi/4.7.3/../../../../arm-none-eabi/bin/ld.exe: region `FLASH' overflowed by 5344 bytes
collect2.exe: error: ld returned 1 exit status
This is by simply calling the exported makefile. The command line this generates is:
arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -fno-common -fmessage-length
=0 -Wall -fno-exceptions -ffunction-sections -fdata-sections -fomit-frame-pointe
r -MMD -MP -DNDEBUG -Os -DTARGET_KL05Z -DTARGET_M0P -DTARGET_CORTEX_M -DTARGET_F
reescale -DTARGET_KLXX -DTOOLCHAIN_GCC_ARM -DTOOLCHAIN_GCC -D__CORTEX_M0PLUS -DA
RM_MATH_CM0PLUS -DMBED_BUILD_TIMESTAMP=1418324231.0 -D__MBED__=1 -DTARGET_FF_ARD
UINO  -std=gnu++98 -fno-rtti -I. -I./external/mbed -I./external/mbed/TARGET_KL05
Z -I./external/mbed/TARGET_KL05Z/TARGET_Freescale -I./external/mbed/TARGET_KL05Z
/TARGET_Freescale/TARGET_KLXX -I./external/mbed/TARGET_KL05Z/TARGET_Freescale/TA
RGET_KLXX/TARGET_KL05Z -I./external/mbed/TARGET_KL05Z/TOOLCHAIN_GCC_ARM  -o main
.o main.cpp
Then the linker generates the error:
arm-none-eabi-gcc -mcpu=cortex-m0plus -mthumb -Wl,--gc-sections --specs=nano.specs
-u _printf_float -u _scanf_float -Wl,-Map=frdm_serial.map,--cref -T./external
/mbed/TARGET_KL05Z/TOOLCHAIN_GCC_ARM/MKL05Z4.ld
-L./external/mbed/TARGET_KL05Z/TOOLCHAIN_GCC_ARM  -o frdm_serial.elf main.o
external/mbed/TARGET_KL05Z/TOOLCHAIN_GCC_ARM/retarget.o
external/mbed/TARGET_KL05Z/TOOLCHAIN_GCC_ARM/system_MKL05Z4.o
external/mbed/TARGET_KL05Z/TOOLCHAIN_GCC_ARM/board.o
external/mbed/TARGET_KL05Z/TOOLCHAIN_GCC_ARM/cmsis_nvic.o
external/mbed/TARGET_KL05Z/TOOLCHAIN_GCC_ARM/mbed_overrides.o
external/mbed/TARGET_KL05Z/TOOLCHAIN_GCC_ARM/startup_MKL05Z4.o
-lmbed  -lstdc++ -lsupc++ -lm -lc -lgcc -lnosys -lmbed  -lstdc++ -lsupc++ -lm -lc
-lgcc -lnosys
The code is surprisingly simple...
Serial uart(PTA0, PTA1);
DigitalOut blinky(LED1);
    for(;;)
        wait_ms(100);
        blinky = !blinky
    return 0;
Compiling much more complex programs in the online compiler is not an issue. So is this a bug from the GCC toolchain? Or related to my building on Windows?
Any help would be greatly appreciated
The FRDM-KL05Z is an ultra-low-cost development platform enabled by the Kinetis L Series KL0x MCU family built on the ARM® Cortex™-M0+ processor. Features include easy access to MCU I/O, battery-ready, …
Edit: Yeah, what Martin said :)
Try removing these two options from the linker command line and see what happens:
That should discard a bunch of floating point code that the UART streaming support pulls in.
I hope that helps,
Adam
Hot diggity! Removing -u _printf_float -u _scanf_float did it.
arm-none-eabi-size Blinky.elf text data bss dec hex filename 16912 136 460 17508 4464 Blinky.elf
I already played with optimizations without any luck.
For future reference the KL05z has 32kB of flash:
Blinky with  -u _printf_float -u _scanf_float:
  32360     228     608   33196    81ac Blinky.elf
Blinky without  -u _printf_float -u _scanf_float:
   9720     128     352   10200    27d8 Blinky.elf
Blinky without  -u _printf_float -u _scanf_float with serial:
Still seems high for just a LED and uart though?
posted by K. N. L. V. 12 Dec 2014
you did not specify the size of blinky without uart, the size of KL05Z (not all of us know all flash/ram sizes from top of our heads).
I would start removing floating support specs=nano.specs -u _printf_float -u _scanf_float, and play with optimizations, use LTO?
