10 years, 7 months ago.
How to control sk6812wwa digital white color to turn different 1800k to 7000k
Hi I have got some sk6812wwa led strip,which declare it can acheive the white color cct from 1800k to 6500k in one smd led. but I how to control it to mix the different white cct as I want,such as 2500k,3500k,4000k and so on. by the way,the ic they use it SK6812 ,which is similar to ws2812. the datasheet about it: http://www.rgbledcolor.com/sell-2393587-sk6812wwa-led-white-color-cct-1800k-to-6500k.html#.VcBgl_Oqqko
anyone can help will be grateful. thanks
Hi the actual datasheet is: http://www.szledcolor.com/download/SK6812%20LED.pdf
you have to send 24bits (3x8bits for the Green:Red:Blue Leds) and if you casade the Led/IC then you have to send n*24bits where n is the number of led/ics that you have The data is serial asynchronous and the structure of the pulses are in the data sheet Regards
posted by Martin Simpson 04 Aug 2015
