11 years, 1 month ago.
Can't import a library
Hello everyone,
Yesterday I was able to /media/uploads/WingNut/import_library.jpg, and all went well. Today, when I tred to do this I get:
/media/uploads/WingNut/capture.jpg
As you see, the 'Import' button never becomes selectable. What changed? I'd like to try out some of the thousands of code available.
Thanks, Duane
The compiler doesn't know which program you want to import the library into. You can select the program you want to import into via the Target Path: field in that dialog you show above.
I hope that helps,
Adam
